Backup FWSM config with RME 4.05
Oct 2nd, 2007
What is the safest way to backup config with RME 4.05?
I had the following config in the FWSM and RME couldn't get the config:
aaa authentication ssh console TACACS+
aaa authentication enable console TACACS+
aaa authentication telnet console TACACS+ LOCAL
If I remove "enable consol" statment it works if I put in the "enable" password for the FWSM in credentials in RME.
But is there another way to backup with RME?
ebreniz Mon, 10/08/2007 - 08:44
You have to give the enable password of the device to the RME because RME will require access to the device to get the access. I think FWSM multiple context is not yet supported in RME but i am not sure.
