ACS - Functional Query
Oct 2nd, 2007
We have Two DataCenter one in INDIA and another in HONGKONG
We want to deploy ACS at both location and ensure if ACS Server in INDIA is down then users can connect through HONGKONG ACS-Server.....
<Q1> How many licenses do I need for ACS
<Q2> How will the server replicate with each other... what is required..?? What is the frequency of replication??
<Q3> Does ACS latest version integrate well with Windows 2003 Active Directory
Appreciate your reply.
Thanks to all
darpotter Wed, 10/03/2007 - 00:16
A1. Two, one for each
A2. ACS Db replication - you'll need to choose one of your servers as a master and the other a slave.
A3. Yes
re A2. You could opt to have a 3rd ACS which is a "config master" - ie the one you make admin changes on. The India & HK servers are "production slaves" who get their config replicated down from the master.
A bit more expensive, but its how I would do it.
Amin Shaikh Wed, 10/03/2007 - 15:38
Thanks for your reply.... I like your idea of 3rd ACS server ...plz help me with following query
I would have multiple admins so how could your suggestion works.... Please Ellaborate using the following points....
If admin in INDIA wants to create an account where would he create it.....
Do you any cisco link explaining in more details about the scenario with implementation examples...
Which ACS version would you recommend
