problem with dhcp client
Oct 2nd, 2007
hi, i have a cisco soho 91.
i have a problem with client dhcp: on e0 of my router there is my lan and e0 have a static ip (192.168.2.0), WAN port must have dinamic ip assigned by ISP. this is my configuration:
Router#sh run
Building configuration...
Current configuration : 3402 bytes
version 12.3
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname Router
no logging buffered
logging rate-limit 500
enable secret 5 xxxxxxxxxxxxxxxxxxxx
username Router password 7 xxxxxxxxxxx
no aaa new-model
ip subnet-zero
no ip source-route
ip tcp selective-ack
ip tcp window-size 2144
ip tcp synwait-time 50
no ip bootp server
ip cef
interface Ethernet0
ip address 192.168.2.1 255.255.255.0
ip access-group 130 in
ip nat inside
no cdp enable
interface Ethernet1
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip nat outside
duplex auto
no cdp enable
ip nat inside source list PERMISSIONI_NAT interface Ethernet1 overload
ip classless
no ip forward-protocol udp bootps
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
no ip http server
no ip http secure-server
ip access-list standard PERMISSIONI_NAT
permit 192.168.2.0 0.0.0.255
but i don't recive any ip.
now post result of debug dhcp det
chmod700-r Tue, 10/02/2007 - 04:46
*Mar 1 00:40:40.267: DHCP: Waiting for 10 seconds on interface Ethernet1
*Mar 1 00:40:44.619: DHCP: QScan: Purging entry
*Mar 1 00:40:44.619: DHCP: deleting entry 814549E4 0.0.0.0 from list
*Mar 1 00:40:44.619: Temp IP addr: 0.0.0.0 for peer on Interface: unknown
*Mar 1 00:40:44.619: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:44.619: DHCP Lease server: 0.0.0.0, state: 8 Purging
*Mar 1 00:40:44.619: DHCP transaction id: 25FE
*Mar 1 00:40:44.619: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:44.619: No timer running
*Mar 1 00:40:44.619: Retry count: 0 Client-ID:
*Mar 1 00:40:44.619: Hostname: Router
*Mar 1 00:40:50.267: DHCP: Try 3 to acquire address for Ethernet1
*Mar 1 00:40:50.267: DHCP: allocate request
*Mar 1 00:40:50.267: DHCP: zapping entry in DHC_PURGING state for Et1
*Mar 1 00:40:50.267: DHCP: new entry. add to queue
*Mar 1 00:40:50.271: DHCP: SDiscover attempt # 1 for entry:
*Mar 1 00:40:50.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:50.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:50.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:50.271: DHCP transaction id: 2600
*Mar 1 00:40:50.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:50.271: Next timer fires after: 00:00:03
*Mar 1 00:40:50.271: Retry count: 1 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:50.271: Hostname: Router
*Mar 1 00:40:50.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:50.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:50.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:53.271: DHCP: SDiscover attempt # 2 for entry:
*Mar 1 00:40:53.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:53.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:53.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:53.271: DHCP transaction id: 2600
*Mar 1 00:40:53.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:53.271: Next timer fires after: 00:00:03
*Mar 1 00:40:53.271: Retry count: 2 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:53.271: Hostname: Router
*Mar 1 00:40:53.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:53.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:53.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:56.271: DHCP: SDiscover attempt # 3 for entry:
*Mar 1 00:40:56.271: Temp IP addr: 0.0.0.0 for peer on Interface: Ethernet1
*Mar 1 00:40:56.271: Temp sub net mask: 0.0.0.0
*Mar 1 00:40:56.271: DHCP Lease server: 0.0.0.0, state: 1 Selecting
*Mar 1 00:40:56.271: DHCP transaction id: 2600
*Mar 1 00:40:56.271: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:40:56.271: Next timer fires after: 00:00:03
*Mar 1 00:40:56.271: Retry count: 3 Client-ID: cisco-0012.d9ae.1905-Et1
*Mar 1 00:40:56.271: Hostname: Router
*Mar 1 00:40:56.271: DHCP: SDiscover: sending 293 byte length DHCP packet
*Mar 1 00:40:56.271: DHCP: SDiscover 293 bytes
*Mar 1 00:40:56.275: B'cast on Ethernet1 interface from 0.0.0.0
*Mar 1 00:40:59.271: DHCP: QScan: Timed out Selecting state
*Mar 1 00:41:10.267: DHCP: QScan: Purging entry
*Mar 1 00:41:10.267: DHCP: deleting entry 8147AABC 0.0.0.0 from list
*Mar 1 00:41:10.267: Temp IP addr: 0.0.0.0 for peer on Interface: unknown
*Mar 1 00:41:10.267: Temp sub net mask: 0.0.0.0
*Mar 1 00:41:10.267: DHCP Lease server: 0.0.0.0, state: 8 Purging
*Mar 1 00:41:10.267: DHCP transaction id: 25FF
*Mar 1 00:41:10.267: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
*Mar 1 00:41:10.267: No timer running
*Mar 1 00:41:10.267: Retry count: 0 Client-ID:
*Mar 1 00:41:10.267: Hostname: Router%Unknown DHCP problem.. No allocation possible
what is the problem?
there is a mistake in my configuration?
what kind of device is upstream from your E1 interface? (i.e. cable modem? adsl modem?).
Depending on what device it is have your power-cycled that upstream device? Some cable devices will cache a single MAC Address and if you switch downstream devices, the newly attached device will not receive an IP if the cable device has not been power cycled.
chmod700-r Tue, 10/02/2007 - 06:30
after E1 interfaces there are 5 wireless antennas (5GHz) and after there is a dhcp server.
