4 Port Switch module on Router
Oct 2nd, 2007
I have 4Port Switch Module installed on 3640 Router but cannot assign IP address to it...
Is there a way to assign IP address to these ports....
let me knwo the steps as well....
Thank You
Kevin Dorrell Tue, 10/02/2007 - 05:03
  • Green, 3000 points or more
I'm not sure whether the 4-port behaves in the same way as the 16-port, but on the 16-port version you assign the switchports to a VLAN, then you create an SVI interface to represent the VLAN at layer-3, and then put the IP address on that.
Kevin Dorrell
Luxembourg
Edison Ortiz Tue, 10/02/2007 - 05:05
  • Hall of Fame,
    Founding Member
These are layer2 ports but you can create a Vlan, assign a Vlan membership to those ports and create a Switch Virtual interface.
For instance:
1) Create Vlan
vlan database
vlan 2 name Vlan2
exit
2) Assign membership
interface f0/1
sw mode access
sw access vlan 2
3) Create SVI
interface vlan 2
ip address x.x.x.x x.x.x.x
Amin Shaikh Tue, 10/02/2007 - 09:58
Thanks for your reply....
I read some post and it as well narrates the same...
Cheers
hoskuldurh Thu, 10/04/2007 - 07:23
Does entering "no switchport" before you do ip address etc... work? It works in dynamips :-)
Kevin Dorrell Thu, 10/04/2007 - 07:26
As far as I know, the 16-port NM supports layer-3 ports, but the 4-port WIC does not. Can anyone confirm that? Does the dynamips support it on both modules?
If the dynamips supports it but the real one doesn't that is very very interesting.
Kevin Dorrell
Luxembourg
Edison Ortiz Thu, 10/04/2007 - 07:50
  • Hall of Fame,
    Founding Member
The 'no switchport' command works but you can't make that port a routed port.
Verification:
interface FastEthernet1/1
description To R1 F0/0
no switchport
ip address 192.168.1.7 255.255.255.0
interface FastEthernet0/0
duplex auto
speed auto
Rack1SW1#ping 192.168.1.1
*Mar 1 00:16:27.987: IP: tableid=0, s=192.168.1.7 (local), d=192.168.1.1 (FastEthernet1/1), routed via RIB
*Mar 1 00:16:27.991: IP: s=192.168.1.7 (local), d=192.168.1.1 (FastEthernet1/1), len 100, sending
*Mar 1 00:16:27.995: IP: s=192.168.1.7 (local), d=192.168.1.1 (FastEthernet1/1), len 100, encapsulation failed.
Success rate is 0 percent (0/5)
In short, it does not work :)
Kevin Dorrell Thu, 10/04/2007 - 08:12
Is that dynamips or the real thing?
Edison Ortiz Thu, 10/04/2007 - 09:10
  • Hall of Fame,
    Founding Member
dynamips.
Also tried on the real thing, same result.
It's a layer2 port.
