right fax with cme
Oct 2nd, 2007
we have a right fax installation with cme.
its working fine except that after sometime the fax is not responding and
we are getting user busy though nothing is goin to rightfax.
i am attaching the fax config and isdn debug which shows busy status.
here is router config.
dial-peer voice 9 voip
description (H323 Link to Rightfax)
destination-pattern 1...
voice-class h323 1
session target ipv4:
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
codec g711alaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
blumcapital Tue, 10/09/2007 - 10:12
We had this same exact issue. The fix was to apply FP2 to RightFax (assuming you are running version 9.3). Then, you will need to contact Captaris technical support and reference Defect ID 61784. The patch included in that Defect ID addresses the dead air problem by upgrading the fax board driver.
