2811 Router questions ---- Router noob
Oct 2nd, 2007
If I add another T1 card into my 2811 to connect to an additional offsite location how would it be represented? Would it be Serial0/1/0:0?
Also if I added in an ethernet card into the 2811 can I have Ethernet 0/0 and 0/1 both going to the same switch and have both addressed to the same subnet?
Below is the snippit of my current T1 setup although I have changed the identifying info such as IP, DLCi and naming.
interface Serial0/0/0:0
description Connection to nyctny MCI-C500-501
no ip address
no ip proxy-arp
encapsulation frame-relay IETF
load-interval 30
no fair-queue
frame-relay traffic-shaping
hold-queue 75 out
interface Serial0/0/0:0.500 point-to-point
bandwidth 1536
ip address 192.168.255.55 255.255.255.252
ip access-group serial0_0_0.500 in
no cdp enable
frame-relay class MCI_t1_t1
frame-relay interface-dlci 500
crypto map SecureMe
Overall Rating: 4 (1 ratings)
Edison Ortiz Tue, 10/02/2007 - 12:29
Yes, on the T1 query
No, on the LAN interface query. Both physical interfaces can't have overlapping subnets.
