Switch MAC Address
Oct 2nd, 2007
Does a Catalyst 2950 switch have only one MAC address? Is this address associated with a network interface card? Is this MAC address associated with the IP address and default-gateway of the switch? Does the 2950 switch have only one MAC address?
Overall Rating: 5 (5 ratings)
rayroyaleverest Tue, 10/02/2007 - 08:14
Does the switch also have an MAC address associated with its management IP address? How are all of these MAC addresses observed?
rayroyaleverest Tue, 10/02/2007 - 09:18
How many IP addresses are associated with the 2950 switch? Is each IP address associated with an MAC address?
ankbhasi Tue, 10/02/2007 - 09:26
  • Cisco Employee,
Hi Friend,
2950 is a layer 2 switch so you can have only one logical layer 3 interface up and up and you can have only one ip address assigned to this interface for management purpose. Now because only one layer 3 interface which is also known as vlan interface can be configured and be active at a time this interface will be having its own mac address.
2950 switch itself have one base mac address and the layer 2 interface and one layer 3 logical interface will have their own mac addresses.
Ankur
rayroyaleverest Tue, 10/02/2007 - 10:34
Can I telnet to this management ip address via an ethernet port address?
ankbhasi Tue, 10/02/2007 - 21:33
  • Cisco Employee,
Hi Friend,
You can telnet to the switch using management ip address from anywhere in the network if you have routes to reach that subnet.
I did not understood you last statement "via an ethernet port address".
Ankur
ankbhasi Wed, 10/03/2007 - 06:09
  • Cisco Employee,
Hi Friend,
If you issue a command "sh version" you will get the base mac address of the switch and if you issue a command "sh interface vlan " you will get the mac address assigned to that layer 3 logical interface.
Ankur
