3560 SFP Troubles
Oct 2nd, 2007
I am trying to connect 2 3560's via the SFP ports and I am only getting link light on one end and only one switch shows connected with an active trunk. The other switch sees the module but will not recognize the trunk and never does show connected or link.
The SFP's that I have tried are GLC-SX-MM and SFP-GE-S. The distance between the buildings is less that 500ft.
I am on 850-nm Fiber between buildings and it is currently working with a 6509 and a 4006. If I feed out of a gbic on the 6509, I get the same thing when attaching to the 3560.
Any help would be greatly appreciated,
-Dan
claforest Tue, 10/02/2007 - 11:04
Check your console for this message:
%GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi#/#/## has bad crc
Thats what it was in my case...
spremkumar Tue, 10/02/2007 - 22:23
  • Red, 2250 points or more
hi
As other poster mentioned do check out the logs in your switch to have more info on the kinda problem you are facing with and also the reason for the same.
regds
dan.cronin Wed, 10/03/2007 - 06:25
I have checked the logs and did not have any errors, I looked at that prior to posting. However, the problem is resolved, come to find out I had some bad fiber between buildings.
Thanks for the replies and help.
