Phone CSS and hunt issue
Oct 2nd, 2007
  • Bronze, 100 points or more
Guys,
runnning ccm 5.1.2 and am having an intermittent issue with some phones. i have a phone in a hunt and if i change the css on that phone i can make the appropriate calls etc. however, when i attempt to call to the phone it goes directly to the hunt group it was associated with. if i remove the phone from the hunt it still does goes to the hunt.
i know it sounds like a css issue, but the css if i call any other phone it the new css it works as it should.
any ideas?...BTW if i reboot the Server it fixes it.
sadbulali Mon, 10/08/2007 - 10:46
To find the association between the Directory Numbers (DNs) and the Calling Search Spaces (CSSes), refer to the "NumPlan" Structured Query Language (SQL) database table. Go to the CallingSearchSpace table to locate the name of the CSS.
This is an example from a lab server. In this example, extension number 3001 is using a CSS named CSS_E:
Table name: 'NumPlan'
column name: DNOrPattern
value: 3001 --> directory number
column name: fkCallingSearchSpace_SharedLineAppear
value: {7AD3D293-A28E-4568-857F-E259A58DDA87} --> CSS identifier
Table name: 'CallingSearchSpace'
column name: pkid
column name: Name
value: CSS_E --> Name of the CSS
For more information, refer to Understanding and Using Partitions and Calling Search Spaces with Cisco CallManager.http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094b53.shtml
a.gooding Tue, 10/09/2007 - 15:32
Does this apply to call manager 5.1?
Dennis Mink Tue, 10/09/2007 - 19:17
  • Blue, 1500 points or more
CM 5.x.x runs IBM Informix as its DB not SQL. I cant imagine the above comment refers to the 5 versions
