Up / Down VPN Client
Oct 2nd, 2007
What`s happening? I connect , stay connected for limited time, but , down my tunnel. Under, the log of the VPN Client.
Cisco Systems VPN Client Version 4.8.00.0440
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 14:52:59.737 10/01/07 Sev=Warning/3 GUI/0xA3B0000B
Reloaded the Certificates in all Certificate Stores successfully.
2 15:48:12.396 10/01/07 Sev=Warning/2 IKE/0xA3000067
Received an IPC message during invalid state (IKE_MAIN:507)
Renewing
1 13:11:21.663 10/03/07 Sev=Warning/3 GUI/0xA3B0000B
2 13:30:53.054 10/03/07 Sev=Warning/2 IKE/0xA3000067
3 13:30:53.850 10/03/07 Sev=Warning/2 IKE/0xA3000067
4 13:44:57.901 10/03/07 Sev=Warning/3 CM/0xA3100027
Adapter address changed from 10.59.30.85. Current address(es): 10.213.11.3.
5 13:44:57.932 10/03/07 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: DeleteIpForwardEntry, error 87
6 13:44:57.932 10/03/07 Sev=Warning/2 CVPND/0xA3400015
7 14:13:15.001 10/03/07 Sev=Warning/2 IKE/0xA3000067
amritpatek Mon, 10/08/2007 - 10:50
  • Silver, 250 points or more
You can increase the connection timeout value as a workaround for this problem. Also you should change the client to allow for transparent tunneling. The error "Error with call to IpHlpApi.DLL: DeleteIpForwardEntry" is cosmetic and means that the client fail to delete the routing table based on split tunnel.
