10-02-2007 09:24 AM - edited 03-05-2019 06:49 PM
i am trying to get to config mode on the rmaed part but get error.
% Warning: Waiting for draco inventory message from SP.
% Reload MSFC without saving configuration if the MSFC does not recover.
% Configuration allowed only from Primary
also 16/1 show errdisable i am however able to session to it. can someone please help me with this.
10-02-2007 09:38 AM
Hi Friend,
Here is an explanation on the error message that you are seeing on the
switch.
Explanation:
Upon Supervisor switchover, there is a message from the active supervisor
which tells who is the Master and who is the Slave. In this case, it is possible
that this message is lost or not sent by the supervisor.
The standby MSFC does not know whether it is the master or slave, so we can not make
configuration change and this is why we need to try reloading the session 16.
I would suggest you the following troubleshooting steps during a maintenance window.
1. Backup config from the sup and MSFC
2. Try to reload module 16
(enable) reset 16
3. If the module not comes up try to reseat the standby supervisor
4. If you still experience the same symptoms allow session 15 to come up as Master
(enable) set module disable 16
(enable) reset 15
Verify session 15 has come up in ok status on the output of "show module"
Bring up the module 16 if session 15 is in ok status
(enable) set module enable 16
Verify session 16 with "show module"
Ankur
*Pls rate all helpfull post
10-02-2007 09:41 AM
getting error
Cannot diable MSFC Module
10-02-2007 09:46 AM
Hi Friend,
Which module you are trying to disable? I believe you have Hybrid Mode running on your switch?
Also can you try reseating the standby sup again.
Ankur
10-02-2007 09:50 AM
module 16. hybrid. i have reseating the standby same thing. i am not able to reset the active right now. will try when i have an open window to do so.
