IPAddressProvider. The app never ends (Java). CCM4.1
Oct 2nd, 2007
When I make an intance of the IPAddressProvider, the application never ends. Im making some test with a Java Main class, but ones I do the instance the methods never ends. Its like it hold the conection with the callManager and then I have to stoped manualy. And, if i do another request just after stoped, it sends a IPAddressProvider.getDeviceList() request failed error.
Its this normal?
What can I do?
The code:
IPAddressProvider ipProv = new IPAddressProvider(callanager, callManagerUserId, callManagerPassword,true);
stephan.steiner Thu, 10/11/2007 - 08:01
Since you have the source code of that class as part of the SDK, I'd include Cisco's classes, or recreate the class library, and with a smart IDE, it'll allow you to step into Cisco's code to figure out what is going wrong.
Loading an IP address report can take a significant amount of time though, so if it doesn't return after a few seconds, that's normal.. it can take multiple dozens of seconds for an installation with several hundred phones.. and if you're looking at thousands of phones....
raymondcidad Tue, 10/16/2007 - 10:57
1. How can I see the SDK codes?
2. It?s not a delay time problem. If I run these simple code, it never ends.
code:
public static void main(String[] args) {
String callManager = "10.145.2.11";
String callManagerUserId = "Administrator";
String callManagerPassword = "XXXX";
IPAddressProvider ipProv = new IPAddressProvider(callManager, callManagerUserId, callManagerPassword,true);
System.out.println("It print just fine");
After the message is print in the console, the app get freeze....
stephan.steiner Tue, 10/16/2007 - 11:29
I suppose you do have the SDK already since that class comes with the SDK. So when you install it, in the installation folder you have a directory Java, which contains the CiscoIPPhoneSDK.jar file that you're using. There are two subdirectories though, javadocs, which contains the javadoc documentation, and src, which contains the source code.
