10-02-2007 11:49 AM - edited 03-11-2019 04:19 AM
I have one more question as a result of a lab setup.I have 2, 3640s...I have their configs below.
One 3640 can ping 129.4.4.4 and it is natted to outside interface of ASA which is 140.1.1.1.
The other 3640 can ping 130.4.4.4 which is natted to outside interface of ASA..
However, if I do an extended ping from the outside nat interface....it can't find its way.
I also tried putting a laptop on the outside ethernet port of one of the 3640s...it can ping the outside interface of the ASA just fine....but can't ping 130.4.4.4 which is natted to the outside IP of the ASA.
Router one
Router#show run
Building configuration...
Current configuration : 1170 bytes
version 12.1
hostname Router
logging buffered 16384 debugging
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default local
username jcornelson privilege 15
ip subnet-zero
no ip finger
Router#
Router#show run
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
aaa new-model
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
cns event-service server
interface Ethernet0/0
ip address 140.x.x.2 255.255.255.0
ip nat inside
full-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 2.x.x.2 255.255.255.0
ip nat outside
full-duplex
router ospf 1
log-adjacency-changes
redistribute connected subnets
redistribute static subnets
network 2.2.x.x.0.0.255 area 0
network 140.x.x.0 0.0.0.255 area 0
ip nat inside source static 140.1.1.1 130.4.4.4
ip classless
ip route 0.0.0.0 0.0.0.0 140.1.1.1
no ip http server
dial-peer cor custom
end
_____________________
Router 2
router3640#show run
Current configuration:
version 12.0
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname router3640
logging buffered 16384 informational
aaa new-model
enable secret xxx
enable password xxx
username jcornelson privilege 15 password 0 cisc0007
ip subnet-zero
no ip domain-lookup
process-max-time 200
ip address 140.x.x.3 255.255.255.0
no ip directed-broadcast
ip nat inside
interface Serial0/0
no ip address
shutdown
ip address 3.x.x.3 255.255.255.0
ip nat outside
no keepalive
interface Serial0/1
no ip address
shutdown
router ospf 1
network 3.3.x.x.0.0.0 area 0
ip nat inside source static 140.x.x.1 129.4.4.4
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
end
Below is diagram. If I ping 129.4.4.4 from router 1, it works. If I do extended ping from router one with 3.3.3.3 as the source it doesn't work.
Same problem is on the other router.
laptop 2.2.2.3
def gate 2.2.2.2
__________
outside 3.3.3.3 outside 2.2.2.2
Router one router3640
inside 140.1.1.3 inside 140.1.1.2
outside 140.1.1.1
ASA 5510
router 1ip nat router3640 ip nat
140.x.x.1 129.4.4.4 140.x.x.1 130.4.4.4
This really has me baffled. I shouldn't have to put static routes to the natted address....which doesn't work anyway. I am not sure what is going on.
10-02-2007 12:50 PM
Hi Joe
Can you just confirm that your ASA has a route back to 2.2.2.x and 3.3.3.x networks.
If not you need to add routes for the individual networks onto your ASA.
If you do, could you post relevant part of config and i can lab it up tomorrow.
Jon
