#DEVICENAME# param.
Oct 2nd, 2007
I kown the #DEVICENAME# param can be defined to be send when one publish the service in the callManager.
But, what if I need the phone to make a request to de application url directy? how can I define this #DEVICENAME# param to be send by the phone.
example, if I made a CiscoIPPhoneMenu and one menu item send you to another URL, how can I do????
I?m trying only by setting the url http://xxxxx.jsp?device=#DEVICENAME# in the CiscoIPPhoneMenu but it doesnt work... :(
Thanks a lote!
ckatene Wed, 10/03/2007 - 14:51
  • Bronze, 100 points or more
just leave the parameter off. If you configure a URL as the phone's services URL, when the phone makes a request to the URL it will add the parameter 'name' to the request with the devicename.
disclaimer: haven't done this for a while. it used to work this way, but knowing cisco's commitment to backward compatibility (or lack thereof) ...
Sascha Monteiro Fri, 10/05/2007 - 23:36
  • Silver, 250 points or more
the 1st url (the one in the ipphone service o.e.) should have the device=#DEVICENAME# in the request, in that page you just need to "extract" that parameter and pass it onto the next url, i.e.
String theDevice = request.getParameter("device");
and then you can use that to populate your URL's like this;
String theUrl = "http://xxxx.jsp?device="+theDevice;
hth
Sascha
n.rungjitwaranon Mon, 11/12/2007 - 21:38
Does the IP Phone also send it's model name when requesting the service?
I have some problem when displaying contents on 7911 screen while 7940 can display correctly. So I would like to write a script to check the model name before showing the contents. Please help.
Thank you in advance.
ckatene Mon, 11/12/2007 - 23:27
yes it does, from memory. but its a header field, not an http parameter. do a trace of a request and you should see it.
