10-02-2007 12:14 PM - edited 03-03-2019 07:00 PM
Hello everyone,
I need some help configuring MLPPP for an NxT1 (3MB) for internet access. My ISP will not support me with the config unless they supply the router and I don't know anything about MLPPP configs except for what I can find on the cisco support site, etc. They haven't installed the circuit yet, so this is obviously just a pre-configuration, but does it look like this should work? Obviously, I am making a couple of assumptions (no CHAP, etc).
This is what I have come up with so far:
Building configuration...
Current configuration : 1657 bytes
version 12.4
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
username *** privilege 15 secret 5 ***
interface Multilink1
ip address 1.2.3.4 255.255.255.252
ppp multilink
ppp multilink group 1
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 10.10.10.1 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
ip address 1.2.3.5 255.255.255.224
duplex auto
speed auto
interface Serial0/0/0
bandwidth 1536
no ip address
encapsulation ppp
shutdown
no fair-queue
pulse-time 6
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1/0
bandwidth 1536
no ip address
encapsulation ppp
shutdown
no fair-queue
pulse-time 6
ppp multilink
interface Virtual-Template1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 Multilink1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
router#
Thanks everyone for your help and patience.
Solved! Go to Solution.
10-02-2007 03:03 PM
Jonathan
Since we do not know what router platform or what card is being used, it is difficult to comment on specifics of what is required. If you found a reference on the Cisco site that indicates that you need it, then perhaps you should leave it in - at least until you have a chance to bring up the circuit. If there appears to be anything strange about the operation of the circuit removing that statement would be one of the first things that I would do.
I can also say that I have configured a number of routers with service-module commands under the serial interface and I do not believe that I have needed to code pulse time on any of them.
Rick
10-02-2007 01:07 PM
Jonathan
Just to clarify a bit, the provider is willing to supply a router to do multilink and would do configs for it, but they are not willing to help with configs if it is not their router. Is this a correct understanding? If it is your router and you have done the configs, will they do multilink (they just take no responsibility for your side)?
I have looked through the config - looking harder at the serial and multilink parts. I think that mostly it looks reasonable. I do not usually use the command pulse-time 6. I am not sure why you need it. Otherwise it looks ok to me. And I certainly agree with your assumption about not doing CHAP. I see little point in authenticating a point to point private circuit.
Rick
10-02-2007 01:15 PM
Rick,
You are correct about the ISP. I am sure they will give me the specifics regarding ISP-specific settings once the circuit is installed, but they just won't help me do the initial config of the router. They will do multilink (I bought a 3MB circuit, and they said it uses MLPPP).
As far as pulse-time 6, the cisco site I saw indicated that i needed to put that. If you don't think it's necessary, I am going to remove it.
Thank you VERY much for your help!
Jonathan
10-02-2007 03:03 PM
Jonathan
Rick
