UC 1.2 TTS issues, need help.
Oct 2nd, 2007
Trying to retrieve emails for Text to speech off an exchange 2007 server. It appears from the log that the initial connection is working, but then I get an error showing a certificate issue.
IMAP Event: error: Certificate failure for <server>: Self-signed certificate or untrusted authority:
This is setup for none on the service on UC, and plain text login on the server.
It is failing to login in to the user mailbox. On the Exchange server, nothing is being logged, so it appears that the initial connection is failing. Any thoughts?
lindborg Tue, 10/02/2007 - 14:49
  • Cisco Employee,
Exchange 2007 was not out or even available to test against in beta form back when UC 1.2 was available - it's not supported. MS changed the authentication stuff all around for access to the mailstore.
Unity Conneciton 2.0(1) does support Exchange 2007.
tahequivoice Wed, 10/03/2007 - 04:53
Was able to track down the logs on this and discovered the hangup. The Exchange is sending TLS to the UC, so if I can figure out either how to disable TLS on the Exchange side, or have the UC accept the cert, then it should work.
