Documenting CallManager
Oct 2nd, 2007
Does anyone have any recommendations on software/tools that they have used to document their CallManager configurations? I have found a possible solution at www.cmreports.com, but it is not a tool and I have to basically send the database over to them, I would rather not do that.
any direction would be appreciated.
Overall Rating: 4.5 (2 ratings)
dezoconnor Wed, 10/03/2007 - 03:12
The CMReports software is very good but I don't believe they've released anything for CUCM 5/6.x
The document they produce is very comprehensive and it'll save you a lot of time in doing screenshots.
Personally, I've not heard of or used anything else to document CUCM.
e.huntley Wed, 10/03/2007 - 12:36
If you have a 4.x system, I would highly recommend CMReports. I have used them several times. I have spoken to them personally before. Basically, it is some guys in the business who figured out a cool way to make the process easier. I would not worry about privacy concerns or anything like that.
It will cost you $60 a pop for each cluster your need to do and $60 for Unity.
They don't have 5.x or 6.x compatibility yet.
