sharing global routing table with vrf for intra-as traffic
Oct 2nd, 2007
We have a network block of 10.201.0.0/16 which is divided into two subnet 10.201.0.0/18 and 10.201.192.0/18. We are getting a internet feed for each subnet.
10.201.192.0/18 is in global routing table, and 10.201.0.0/18 is in a vrf-lite green.
I am thinking doing the following:
...........HUB
VL199/....\VL198
SPOKE1 SPOKE2
Hub and spoke are from perspective of vrf green.
For vrf green in the HUB:
ip route vrf green 10.201.0.0 255.255 255.192 vlan 199
ip route vrf green 10.201.64.0 255.255.255.192 vlan198
SPOKE1
ip route 0.0.0.0 0.0.0.0 vlan199
SPOKE2
ip route 0.0.0.0 0.0.0.0 vlan198
Suppose we already get the 2 internet feeds to HUB route with vrf green and global routing table. This should get vrf green going.
But we also have global routing table on the HUB router.
We would like to have 10.201.0.0/16 communicating with each other, and only keep internet default separated.
How should we get to 10.201.0.0/18 from global routing table and how should we get to 10.201.192.0/18 from SPOKE[12]?
Overall Rating: 3 (1 ratings)
sding2006 Mon, 10/08/2007 - 10:58
In my lab, I have 2 ports configured.
int gi1/2
ip vrf forward green
ip address 10.201.192.253 255.255.255.252
int gi1/1
ip address 10.201.192.254 255.255.255.252
ip route 10.201.0.0 255.255.192.0 gi1/2
ip route vrf 10.201.192.0 255.255.192.0 gi1/1 10.201.192.254
This way, from vrf green to global has go through HUB. and vrf greens will also go through greens.
Is there any other much elegant way for this purpose?
swaroop.potdar Mon, 10/08/2007 - 12:44
Since you have global table only at the HUB, rather than doing a conventional route leak you can do a physical loopback between 2 interfaces at the HUB, and populate one end with the VRF. So you can inject all the global routes into your VRF. So VRF users can come till hub and exit out the loopbacked interface back to global table, and global users can go directly.
HTH-Cheers,
Swaroop
