VPN Deployment
Oct 2nd, 2007
Hi All
My name Tadben. I am fresh network eng.
Currently i am working on how VPN works.
Can any one tell me the components i need to connect two offices through VPN using the Internet? What hardwares and softwares do i require to do this VPN?
Danilo Dy Wed, 10/03/2007 - 05:58
Tell us what you currently have (router and firewall model). If your current hardware supports or it can support (with updates) VNPN, that would be better as it will not cost you much. Basically, most company uses firewall in their main and remote sites for internet connectivity, network/security architects take advantage of using these existing devices to build site-to-site VPN tunnels between main and remote sites so that the solution will not cost the company a lot of $$$.
Dandy
