Inventory - Serial Number
Answered Question
Oct 2nd, 2007
When I run the inventory report I have the following fields:
Updated At System - Name Domain - Name Description - Serial Number - Contact - Location ...
How can I add the "serial number"
I tried editing credentials but "SN" it's not the same as serial number.
Correct Answer by ebreniz about 9 years 9 months ago
For the chassis serial numbers you either enter then manually using Change Device Attributes or when you add a device manually to the RME database. If you want CampusManager to automatically discover the serial number you need to use the command "snmp-server chassis-id (serial number)" The problem with this is that some devices will not take this command and you have to enter the number manually.
Overall Rating: 5 (1 ratings)
Correct Answer
ebreniz Mon, 10/08/2007 - 13:37
  • Silver, 250 points or more
