ACS Appliance - Where is the bulk import?
Oct 2nd, 2007
On the Windows version there is the command line utility which allows for the bulk import of users and clients. With over 250 TACACS+ client to install on an ACS appliance I do not want to have to add them in manually, one by one, but don't seem to be able to find the way to import them. Can anyone help?
darpotter Wed, 10/03/2007 - 00:13
  • Silver, 250 points or more
On the appliance the only way is to use RDBMS Sync.
The ACS quick help and online docs all have quite good documentation about how to create the account actions transaction table so I wont describe it here.
You can actually set more device params via RDBMS sync than you could csutil.
I doubt its been updated for the new device parameters you can manually setup in ACS v4.1 though.
