Can an 1841 ADSL be configured to point to 2 peers?
Oct 2nd, 2007
At the moment our VPN's (we use 1841, 877 and 837's) point to one peer IP address which is a cisco concentrator. For failover can we point the config to another peer address if it can't contact the first?
Overall Rating: 1 (1 ratings)
hadbou Tue, 10/09/2007 - 06:14
  • Bronze, 100 points or more
The benefit of ADSL over a serial or dial-up line is that it is always on and always connected, increasing bandwidth and lowering the costs compared with a dial-up or leased line. ADSL technology is asymmetric in that it allows more bandwidth from an NSP's central office to the customer site than from the customer site to the central office. This asymmetry, combined with always-on access (which eliminates call setup), makes ADSL ideal for Internet and intranet surfing, video-on-demand, and remote LAN access.
Ttry config to use dynamic crypto maps.
Richard Burts Tue, 10/09/2007 - 06:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
I have not had much experience doing it but I know that you can configure more than 1 peer address in an instance of the crypto map. The documentation indicates that it provides the failover capability that you want. So it sounds like the answer for you.
Rick
Jon Marshall Tue, 10/09/2007 - 09:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Andy
Just to confirm that Rick's suggestion will indeed work and i have used it in a production environment. It will try the peer's in order of entry into the crypto map.
Jon
Richard Burts Tue, 10/09/2007 - 10:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
Thanks for the confirmation. It is always good to hear from someone who can say I did it in a production environment and it works.
Rick
