Push application on Asterisk/Trixbox pro
Oct 3rd, 2007
I want to send a text message to ip phones active on the asterisk.
I'm not sure if the push phone sample on the sdk will work on asterisk since it uses AXL database query to get the list of IP Address.
I want my application to query the Asterisk database for IP address and push message to those phones.
I'm using PHP to code the application..
Danny
msabir Wed, 10/03/2007 - 10:03
  • Bronze, 100 points or more
You can push text and/or audio message to an IP phone group, even if the phones are on asterisk or on CCM simulator. However, you need to manually maintain the list of phones or write a code to grab the phone's IP address. SDK samples use deviceListx.asp to get phone list, which is web page hosted on CCCM
dannyleshaba Thu, 10/04/2007 - 03:09
I know you can use AXl on CCM but on astrerisk i don't know how to go about writing the code to get the IP Addresses.
I don't want to manually insert the IP address, i want the user to just select the name of that person, click the soft key send.
Your help will be highly appreciated.
Cheers Danny.
msabir Thu, 10/04/2007 - 05:17
The only thing you need is phone's IP address to do an HTTP POST of CiscoIPPhoneExecute object. You do not need CCM for pushing text/audio to an IP phone. There should be a way to get Phone's IP address from asterisk.
dannyleshaba Wed, 10/17/2007 - 00:17
One more thing i need to convert the string that i want to push to the to CIP(IPphoneimage). can u please explain the process as i don't really understand how its done. I need to change the text2cip on the SDk to a ph script ans i'm struggling.
dannyleshaba Tue, 11/13/2007 - 01:24
I need to convert my phones back to SCCP image so that i can push messages. The problem is i cannot download the SCCP image files because im registered as a guest on the cisco site. Is there a way i can get the SCCP files?
