Error in CAR
kong_cisco1
I saw the following errors occured in the CDR error log:
"destDevicedestDeviceName in a CDR record is null"
"origDeviceName in a CDR record is null"
"dateTimeConnect in a CDR record is not a positive integer"
Can someone suggest how this happen and how to troubleshoot the problem?
Many Thanks
I'm having the same issue; did You solved ?
Many thanks in advance
Luigi
The error didnt come back again after I clear off the error log.
What version of callmanager are you running?
I've the version 6.0.1-2000.4
Have You cleared them with the purge ? ( in the car-system-database )
many thanks
Luigi
