10-03-2007 03:19 AM - edited 03-05-2019 06:50 PM
I have been given a access to two 4006 switches and been informed that out of which one contains a Cat IOS and other switch contains IOS, with the user mode access, how do I make out which switch has CAT IOS,
can any one help me on this
thanks, Shashi
10-03-2007 03:23 AM
Hi Shashi,
If you see a prompt like "Console> (enable)" then it is running CATOS and if you see a regular enable prompt "Switch# " then it is IOS.
Ankur
*Pls rate all helpfull post
10-03-2007 03:39 AM
From user mode, you can determine the IOS version by running the "show ver" command.
If you're still not sure from the output of the command, post the output here and we'll let you know!
Kind regards
Graeme
