One pri for voice and data
Oct 3rd, 2007
Customer has VWIC-1MFT-T1 in router 28xx or 38xx and currently T1 is configured as PRI for voice. They would like to use 4 channels from this PRI for data and the rest are for voice. is this supported? Thanks
mchandak Wed, 10/03/2007 - 05:02
  • Gold, 750 points or more
AFAIK, this cannot be done with one T1. You will need 2 T1s for this. This not only depends on the Router/T1 card, but even on the Provider. Does the Provider support this configuration ??
ciscoforum Wed, 10/03/2007 - 06:53
I think I saw the following commands before. But couldn't find a link anymore
controller T1 2/1
channel-group 10 timeslots 1-4 (data)
pri-group time slots 5-24 (voice)
