It should be simple but....DND how can I turn it on
mchandak Wed, 10/03/2007 - 05:06
With CallManager, DND Softkey is only activated with IPMA configured. If you are not using IPMA, DND Key cannot be activated.
The following TAC CC case should give you more information about this feature and a WorkAround:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K50314757
The following link has information about how IPMA works:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps5015/products_user_guide_chapter09186a00807bc6ef.html
Hope this helps
