Guest Access Security
Oct 3rd, 2007
We have two wireless controllers in the DMZ that we use for guest access only. Right now the management, ap-management and dhcp addresses for users are all on the same IP segment. I know that's not the most secure way to deploy and wondered what the best practice is for this situation.
Thanks!
ericgarnel Thu, 10/04/2007 - 07:20
  • Gold, 750 points or more
It would be better if you were to seperate out the guest users into their own wlan/vlan/subnet. Assuming that the dmz endpoint allows for multiple subnets and/or vlan/subintefaces (PIX or IOS) You could then drop the guests into a subnet that can only access the internet and not any other local networks. This can also be acheived or aided by ACLs the wlan(s) as well.
Trending Topics - Security & Network
