2811 router connected to a 100MB MAN
Oct 3rd, 2007
My project consists of changing our current t1 MPLS WAN to a 100 MB shared fibr MEtro area network. Can I connect the MAn to the second ethernet connection? What will the throughput be?
Rick
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Wed, 10/03/2007 - 11:00
  • Hall of Fame,
    Founding Member
100 mbps, if wirespeed is desired at any packet size, exceeds 2821 performances. See attached document.
Joseph W. Doherty Wed, 10/03/2007 - 15:55
If your going to use a LAN like connection, you might consider using a LAN L3 switch. The Catalyst 3560-8PC might be a good fit.
