10-03-2007 06:42 AM - edited 03-18-2019 07:54 PM
Is there functionality near to the FXO Trunk Lines in Cisco CallManager. I need to use it like it works in the CallManager Express.
Solved! Go to Solution.
10-03-2007 09:21 AM
You can give the appearance of this functionality by doing the following.
1. Create a speeddial on the phone of 9.
2. Go to Callmanager service parameters and change the Speed Dial Await Further Digits parameter to True.
Now the user can begin dialing the number when they choose this "line". Of course the route patterns will still have to be in place, but it gives the appearance of seizing a line.
Hope this helps. If so, please rate the post.
Brandon
10-03-2007 09:21 AM
Brandon
10-03-2007 11:12 PM
Thank you Brandon, this is very useful answer for me.
Best Regards,
Zdravko
