Restore error in CCM Disaster Recovery System
Oct 3rd, 2007
I managed two CCM PUB & SUB.
One CCM(PUB) occured to fail booting, CCM(SUB) was ok.
Now CCM(SUB) is working IPT service.
For recover this, I reinstall CCM(PUB).
I Backup CCM database & config with Disaster Recovery System from CCM(SUB).
And I restore DATA to new-installed CCM(PUB).
But restore failed with following log.
============== error log message =========
Log File: 2007-10-02-23-25-43_r_ccm1_ccm_ccmdb.log ==========
Server : CCM1
Feature : CCM
Component : CCMDB
Time Completed: 2007-10-02-23-34-37
Result Code : 1
Result String : ERROR
Dropping DB ccm0500v0000
Setting DB to multi user mode
Restoring DB...
CCMDB Restore failed, installdb failed
----> BEGIN Standard Output
Inside getdbnameFromodbc...
Line Matched:
Database=ccm0500v0000
csv file validation in progress...
Validate CSV complete.
Stopping DbMon
Service Manager is running
Cisco Database Layer Monitor[STOPPING]
Component is not running
Cisco Database Layer Monitor[NOTRUNNIG]
Shutting down Replication -- replutil.py teardowndrf
Setting DB to single user mode
Restoring DB...
Create database failed, check .../createdb.log
Failure 1
CCMDB Restore failed, installdb failed, error:
Restore failed.
----> END Standard Output
----> BEGIN Standard Error
+ '[' 3 -lt 3 ']'
+ sudo -u root /usr/local/cm/bin/do_db_restore.sh /common/drf/restore.log
/common/drf/status.txt /common/drf/2007-10-
02-21-55-50/ccm1_ccm_ccmdb.tar
command failed -- Enterprise Replication not active (62)
Database selected.
425: Database is currently opened by another user.
107: ISAM error: record is locked.
Error in line 1
Near character position 26
Database closed.
+ res=1
+ '[' 1 == 0 ']'
+ echo 'Restore failed.'
+ exit 1
----> END Standard Error
Overall Rating: 5 (1 ratings)
mchandak Wed, 10/03/2007 - 08:24
  • Gold, 750 points or more
You cannot take a Backup from the Subscriber and install it on the Publisher. Backup should always be taken from the Publisher and then restored.
Incase you dont have a valid backup of the Publisher, I dont think you can do a DRS Restore.
hut982010 Sun, 08/01/2010 - 20:54
Hi Drazik,
I also have the same error. I only turn on the  Publisher, I stop Cisco Database Layer Monitor, but I still get the error.
If you have resolved the error, please help me to fix it.
Thanks you so much,
Hut982010
