Installing UK English language pack for CUE
Oct 3rd, 2007
The Cisco Configuration Assistant is rubbish and barely works. So I dont want to use that as my Cisco documentation tells me to. How else do I get my language file installed for CUE?
The file I have is:
cue-vm-en_GB-upg-lang-pack.2.2.2_2.3.2.prt1
Cheers
davieshuw Thu, 10/04/2007 - 01:02
Thanks for the link. I only want to install the english voicemail pack, everything else is OK, so im not looking to upgrade my unity express, just get the gnglish language pack for unity. Is the file I have the wrong one u recon?
davieshuw Mon, 10/08/2007 - 02:48
Anyone else able to point me in the direction for installing language packs for CUE?
Cheers :)
anderson-david Mon, 10/08/2007 - 05:22
Hi Huw,
as well as the file above I think you also need the following
cue-vm-lang-pack.2.3.x.pkg (language package file)
cue-vm-language-pack.2.3.x.prt1 (language prompts)
once you have these you do a "software install clean" and point at the .pkg file, the system will see that you want to change a file and you just need to follow the instructions on screen.
This is from memory so hopefully its all there
Dave
