Health Check of a Switch
Oct 3rd, 2007
To check whether a switch is healthy and all is ok what should I be looking for in addition to the following?
show logs
show proc cpu
show proc mem
show env all
What else should I be looking for?
ankbhasi Wed, 10/03/2007 - 09:10
  • Cisco Employee,
Hi Friend,
Which switch is this? If thee are the modular switches then you can also issue a command "sh mod" to check the modules status and "sh test" to give you port and line cards status.
Ankur
jon.axe Wed, 10/03/2007 - 09:34
One additional command I use is the show version command. This command tells me whether the switch was last rebooted by a loss of power or if it was rebooted by a software crash or a hardware failure.
These are good basic commands to use but it is always important to have the latest stable release of IOS installed on your switch.
