NetFlow
Hey Everyone,
I have two 6513's running IOS v.12.2(18)SXF8. I am having issues sending Netflow data to an NFSEN workstation. Basically, when i do "sh ip route cache flow" on switch 1 I see all source ip, source port , dest ip and dest port info. However, when i do the same command on switch two i only see src ip and dest ip info. I need to see all src port and dst port info. I am using nfdump/nfsen to capture all data (which by the way is the best netflow capture tool i have ever used). HEre is the config from each switch. Any ideas would be great! thanks. by the way, i am using a PFC3 card in each device.
Switch 1:
ip flow-cache timeout active 5
ip flow ingress layer2-switched vlan 2,5,65,161,197-198,200
ip flow-export version 5
ip flow-export destination 10.23.20.60 10106
mls ip multicast flow-stat-timer 9
mls flow ip interface-destination-source
no mls flow ipv6
mls nde sender version 5
no mls acl tcam share-global
mls cef error action freeze
switch1#sh mls netflow flowmask
current ip flowmask for unicast: if-dst-src
current ipv6 flowmask for unicast: null
Switch2:
ip flow-export destination 10.23.20.60 10107
no mls flow ipv6
switch2#sh mls netflow flowmask
Konstantin Dunaev Thu, 10/04/2007 - 00:54
hi,
it should be used full or interface-full in oder to get the port information from the Netflow data.
But if there is some netflow-mask conflict (e.g. in case one uses NAT it's not possible to use full-mask for Netflow) then the IOS could take the smaller mask.
