10-03-2007 10:27 AM - edited 03-14-2019 11:53 PM
Once the custom background image is working for the 7970 telephones, we wondered if it was possible to force a particular image across the enterprise. I've tried the "Background Deployment 1.0" product from VoIP Integration but like some others, it doesn't seem to work.
I see how to force the Idle image but not the standard background. Any ideas? This is for CCM 4.x.
10-04-2007 11:35 PM
One thing you can do is to find the image file for the background and then replace it with the background that you wanted. This way it will foce all the phones to download the new image. I've did this before and it worked. The image should be at the tftp folder on your CM server.
10-05-2007 06:17 AM
I'd like to know this too. All of our 7970's are using the default image built into the phone so renaming a file on the TFTP server isn't an option. I don't know why Cisco didn't put this into BAT?
