Securing Guest Wlan
Oct 3rd, 2007
I am trying to set up a WLAN with internal users and guest users.
I have 2 ssid's one visible one hidden, the visible one is for guest use.
Problem is when I connect to the guest wlan and web auth, I can then ping and telnet to the rest of the corporate network. How do I stop this?
Jon Marshall Thu, 10/04/2007 - 10:36
Have you got separate vlans setup ie.
vlan 10 = users
vlan 11 = guest
You would then hand out different IP address ranges for each vlan eg.
vlan 10 =
vlan 11 =
Then you can either use a firewall or use access-lists on the vlan interfaces ie. suppose the coporate network was made up of subnets
Also assume you want to allow your guest users out to the Internet
access-list 101 deny ip
int vlan 11
ip access-group 101 in
This would allow guest users on to access the Internet but not coporate LAN.
r.robins Fri, 10/05/2007 - 06:38
Thanks Jon,
Looks like this is one of two ways to go.
ACL's on the switch/Router or put the WLC onto a DMZ.
Second option just means we use a wlc for 4 AP's taht will provide the Guest access.
Not so bad as we have 4 in total.
