Paolo Bevilacqua Wed, 10/03/2007 - 13:10
Not really, search for "idle url" in this forum for an alternative approach.
hope this helps, please rate post if it does
Rob Huffman Wed, 10/03/2007 - 16:04
Hi Brendan,
Just to add a bit to Paolos good reference. Here are the docs for different CCM versions, they do vary slightly;
Cisco Unified IP Phone 7911G Administration Guide for Cisco Unified CallManager 5.0 (SCCP)
Customizing the Cisco Unified IP Phone
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a00805f2b31.html
Cisco Unified IP Phone 7911G Administration Guide for Cisco Unified CallManager 4.2
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a00806704e5.html
Cisco IP Phone 7911G Administration Guide for Cisco CallManager 4.1(3)
Customizing the Cisco IP Phone
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a00805adae5.html
Hope this helps!
Rob
bmarmont_2 Wed, 10/03/2007 - 16:37
Thanks guys, now the reason behind us wanting to change the logo was that the display names were being truncated, so instead of "Johnny Bloggs" it shows "Johnny Bl" Is there a way of shrinking the logo border so the full name appears?
Thanks again
Rob Huffman Thu, 10/04/2007 - 15:36
Hi Brendan,
You can't shrink the logo :( I'm curious when the name Johnny Bloggs is being truncated. Is it on Incoming calls? Or maybe Text Label?
We don't use 7911's but I tried these two things on 7905's and 7912's which should have the same specs and they worked fine on both.
Let us know,
Rob
Paolo Bevilacqua Thu, 10/04/2007 - 16:11
Thanks much for citing me Rob :)
Actually the '05 and '12 are different from the '11 that is java based. I'm afraid Brendan may indeed have truncated what would show on another phone.
Perhaps a phone FW issue ?
Rob Huffman Thu, 10/04/2007 - 16:32
Hey Paolo,
Well you deserve much praise for your contributions here :) I was kind of thinking of the actual size of the display when referencing the specs, bad idea I guess. Is the logo way different on the 7911 its hard to tell from a picture. Maybe the problem is the new Cisco logo (I quite like it??)
Anyways,enough rambling, I'm sure we can figure this out, you should be able to display more than 8 characters without having it truncate. Probably a bug in the firmware as my friend Paolo suggests.
Take care,
Rob
bmarmont_2 Thu, 10/04/2007 - 18:26
We have just upgraded the CCM and device FW to the latest release for v5 - 5.1.2.3000-2. All handsets were also reset with new FW.
bmarmont_2 Thu, 10/04/2007 - 18:19
Hi Rob, yeah it's the main display, the text label for the users name is truncated. The Cisco logo takes up a large proportion of the screen, not sure who signed off that one ;o)
Rob Huffman Sat, 10/06/2007 - 09:17
Hi Brendan,
Can you please give us the exact phone firmware that the 7911's are using. I did spend some time looking for related bugs but it's hard without knowing this info.
Let us know,
Rob
jaber23 Wed, 11/14/2007 - 08:04
Hello, I'm also having a problem where the 7911 phone's line text label is truncated by the pointless logo. How can this be called a 'background' image if it overwrites the text on the screen. Am I missing something?
bmarmont_2 Wed, 11/14/2007 - 11:29
We still have not got an answer from Cisco, however the firmware release for the 7911 does the truncation by nature, simply a poor design on their behalf. If we get some results I will post it here for you. Meeting with them on Friday.
Rob Huffman Wed, 10/10/2007 - 05:51
Hi Brendan,
I went through all 323 Bugs related to 8.3(1) firmware last night and none were related to this issue. I guess maybe this is working as designed. You could try a Tac case to see if they can shed any light on this.
Sorry my friend! Can you beleive 323 Bugs :(
Rob
