10-03-2007 12:59 PM - edited 03-14-2019 11:53 PM
I have Cisco 1760 voip router with two fxs ports. And have Linksys WAG54GP2-E2 voip router. I make peer-to-peer call. Linksys router can call to cisco but cisco can not call linksys. Does anybody know how i resolve this problem. Thank for help.
Ufuk Guler
Solved! Go to Solution.
10-04-2007 03:02 AM
You are right, I had totally oversight that you was missing that command under DP!
Good that you've found about it eventually.
10-03-2007 01:08 PM
How DP on the 1760 is configured, and what do you see from "term mon" and "debug ccsip message" ?
10-03-2007 01:18 PM
Here is DP,
dial-peer voice 200 voip
description *****CISCO TO LINKSYS*****
destination-pattern 200
voice-class codec 1
session target ipv4:81.x.x.x
dtmf-relay cisco-rtp
no vad
When i test with csim start 200 command i take this messages
csim: called number = 200, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(507)
csim info: cid(507), state(0), cause(38)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
10-03-2007 01:26 PM
cause 38 is network out of order. Please collect the above mentioned debug to find why.
10-03-2007 11:23 PM
I have checked some debug messages which are debug cch323 all. I saw that peer to peer calls like H.323 calls. And linksys accepts only SIP calls. Because of that Cisco's calls unrecognized with Linksys. Then I wrote "session protocol sipv2" command in the dial-peer. And finally, cisco calls started successfull1y to linksys.
I would like to thank you for your help.
Have a nice days...
10-04-2007 03:02 AM
