Pix 501 static nat problems
Oct 3rd, 2007
I have, or am trying to setup static nat on our video conf units. I have configured the units with a private IP. There is also an option on the units to associate them with a public nat ip, which I have done also. I can ping and login through the web interface to them in our lan, I can even ping from these units to the internet. But I can not establish a video connection and outside hosts cant ping them or setup a call. Outside host can ping the firewall ip. I use to have this working back in the spring and then removed the entries and used public IP's on the units. Now I am trying to go back with putting them behind the firewall. Ive doubled checked maybe even triple checked the ip addresses. Any suggestions, if additional info is needed let me know. Thanks in advance.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxx encrypted
passwd xxxxxxx encrypted
hostname FRARM101FW1
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
no fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inbound_access remark ICMP_Return_Packets
access-list inbound_access permit icmp any any echo-reply
access-list inbound_access permit icmp any any time-exceeded
access-list inbound_access permit icmp any any unreachable
access-list inbound_access permit icmp any any source-quench
access-list inbound_access permit icmp any any parameter-problem
access-list inbound_access remark Management_Access
access-list inbound_access permit tcp host 75.x.x.239 host 206.x.x.60 eq www
access-list inbound_access permit tcp host 75.x.x.239 host 206.x.x.61 eq https
access-list inbound_access permit tcp host 75.x.x.239 host 206.x.x.62 eq www
access-list inbound_access remark H323_Initiation
access-list inbound_access permit tcp any host 206.x.x.60 range 1024 65535
access-list inbound_access permit udp any host 206.x.x.60 range 1024 65535
access-list inbound_access permit tcp any host 206.x.x.61 range 1024 65535
access-list inbound_access permit udp any host 206.x.x.61 range 1024 65535
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 206.x.x.59 255.255.255.248
ip address inside 10.10.10.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 10.10.10.49 255.255.255.255 inside
pdm location 75.x.x.239 255.255.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.10.10.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 206.x.x.60 10.10.10.40 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.x.61 10.10.10.41 netmask 255.255.255.255 0 0
static (inside,outside) 206.x.x.62 10.10.10.42 netmask 255.255.255.255 0 0
access-group inbound_access in interface outside
route outside 0.0.0.0 0.0.0.0 206.x.x.57 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authorization command LOCAL
http server enable
http 75.x.x.239 255.255.255.255 outside
http 10.10.10.49 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
rhopkins_nci Wed, 10/03/2007 - 15:00
Well, I tried testing from home, from the 75.x.x.239 address. I could not get a response from ping from .60 and .61 but could from .59, but for some odd reason I could login through the web interface of .60 but not .61. Do you think its something other than my pix config? Thanks.
rhopkins_nci Wed, 10/03/2007 - 17:45
Seems weird replying to myself. But I figured I would explain that I ,hopefully, solved the main problem. I deleted the access-list entries and group, recreated it and applied it back. Works like a charm, I can login thru http and https and make calls from home, but still cant ping .60 and .61. No big deal on that though. If anyone has an tips or suggestion on my config, im all ears.
