MLPPP routing issue
Oct 3rd, 2007
hi,
I have two t1's bonded together using MLPPP. I have all the interfaces, Serial0, Serial1, MLPPP all show up and up.
the issue is I can not send any traffic over the mlppp circuits, I try to ping across but no luck. Attached is my show run and show multilink. Any help would be great.
spremkumar Wed, 10/03/2007 - 22:01
hi
can you check the config line under multilink interface ?
ip address 10.10.10.2 255.255.255.0
is its coz of some typo ? whats the ip address configured at the other end ?
do check this and correct it out that may solve your problem.
regds
royalblues Thu, 10/04/2007 - 02:35
Try clearing the multilink bundle
clear interface multilink
Can you post a sh ip route?
Narayan
a.strobel Thu, 10/04/2007 - 04:02
yes this ip is correct. The other side is 10.10.10.1
Not sure why but when we put in the shoretel voip system they said I had to bridge the two networks instead of just using routing.
