Forced Authorization Code on CCME
We are running CCME 4.0, is it possible for to configure Forced Authorization Code(FCA)on CCME ?
If yes, please let me know what are the configuration parameters needs to be added on CCME for FCA.
5 Replies 5
paolo bevilacqua
There is no FAC on CCME like CM has.
If you are trying to limit calls, you have three solutions:
1. use PIN login with afterhours configuration
2. use COR
3. use a secrete prefix to make certain calls and configure your DP with that.
Thanks for your reply.
Please let me know the configuration details or document for configuring 1 & 3 (PIN Login and sectret prefix).
One more clarification: Can we able to get Call Detail Reports on CCME?
Thanks in advance
Is it true that CCME 4.1 will support FAC?
for configuring pin login and after-hours, please reference configuration guide on CCO:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_book09186a00807c5776.html
for 'secret prefix', just config a new DP with destination-pattern ^2345....T
e.g. 2345 is your secret PIN.
CCME is now versions 4.2 and as I mentioned it does not support FAC like CM does.
Thanks for the rating and good luck!
Some one send me the configuration in attach
I am going to test
I sugets all you to test to and share the results
Brgds
