Reg:isp fail over
Answered Question
Oct 3rd, 2007
Dear sir,
i have one 2821 router in that iam having 1mbps (british telecom)and one more is reliance(2mbps)now i want failover between B.T and reliance.
how can i configure the router.plz kindly give me the examples.
Correct Answer by ankbhasi about 9 years 3 months ago
Hi Srnivas,
Try this out and it should work
interface s0
ip address
ip nat outside
interface s1
ip address
ip nat outside
interface ethernet3
ip address
ip nat inside
ip route 0.0.0.0 0.0.0.0 s0 90
ip route 0.0.0.0 0.0.0.0 s1 100
ip nat inside source route-map ISP1-map interface s0
ip nat inside source route-map ISP2-map interface s1
route-map ISP11-map permit 10
match interface s0
route-map ISP12-map permit 10
match interface s1
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (2 ratings)
spremkumar Wed, 10/03/2007 - 22:12
hi
are you talking about plain internet link or mpls circuit ?
if its internet link then you can have floating static routes which takes care of routing and dual nat statements to take care of your internet access.
regds
vasuramnet Wed, 10/03/2007 - 22:19
Dear premkumar,
thanks for ur valuble reply and its nota mpls link its aplain internet link.Plz give me any examples sir that will greatfull to u
srinivas.d
Correct Answer
ankbhasi Wed, 10/03/2007 - 22:43
Hi Srnivas,
interface s0
ip address
ip nat outside
interface s1
ip address
ip nat outside
interface ethernet3
ip address
ip nat inside
match interface s0
match interface s1
Ankur
