default 2 asa context not working
Answered Question
Oct 3rd, 2007
hello,
i just want to know if the 2 default asa5520 context will work or not.
ive tried configuring but cant make it work at all.
thanks
Correct Answer by Patrick Iseli about 9 years 9 months ago
Have you configured the security (system) for the context ?
http://www.cisco.com/en/US/partner/docs/security/asa/asa70/configuration/guide/mngcntxt.html#wp1070989
sincerely
Patrick
Overall Rating: 5 (1 ratings)
jfgobin01 Wed, 10/03/2007 - 23:29
What did you try ?
Have you issued the "mode multiple" command in configuration ?
jF
cfajardo1_2 Thu, 10/04/2007 - 00:57
YES. CONTEXT ARE CREATED AND CONFIGURATIONS AS WELL.
BELOW IS ONE CONTEXT CONFIG.
CONTEXT_A
sh run
: Saved
ASA Version 7.0(7)
hostname CONTEXT_A
enable password xxx
names
dns-guard
interface GigabitEthernet0/0.2
nameif outside_b
security-level 0
ip address 192.168.13.211 255.255.255.0
interface GigabitEthernet0/1.2
shutdown
no nameif
security-level 0
no ip address
interface GigabitEthernet0/2.2
no nameif
no security-level
no ip address
interface GigabitEthernet0/3.2
nameif inside_b
security-level 100
ip address 10.10.100.254 255.255.255.0
passwd xxxy
access-list outside_b_access_in extended permit icmp any any
access-list outside_b_access_in_V1 extended permit icmp any any
pager lines 24
mtu outside_b 1500
mtu inside_b 1500
no asdm history enable
arp timeout 14400
global (outside_b) 20 192.168.13.212
nat (inside_b) 20 10.10.100.0 255.255.255.0
access-group outside_b_access_in_V1 in interface outside_b
route outside_b 0.0.0.0 0.0.0.0 192.168.13.1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
Cryptochecksum:xxx
: end
jfgobin01 Thu, 10/04/2007 - 01:09
nameif outside_b
security-level 0
Are you trying to trunk on your interface ?
cfajardo1_2 Thu, 10/04/2007 - 01:42
Iam new in this multiple context thing.
What ive done as conventioon is below
CONTEXT 1
g0/0.1 vlan 10
g0/1.1 vlan 110
g0/2.1 vlan 120
g0/3.1 vlan 130
CONTEXT 2
g0/0.2 vlan 20
g0/1.2 vlan 210
g0/2.2 vlan 220
g0/3.2 vlan 230
cfajardo1_2 Sat, 10/06/2007 - 23:41
yes. ive reconfigured it and it works. worst thing is i dont know where ive gone wrong previously. its just not doing the NAT.
thanks a lot.
