Replace drive on Callmanager
Oct 3rd, 2007
  • Silver, 250 points or more
I have to replace on a 7835 a 18GB drive with a bigger drive. I know the official way to do that (make backup install from scratch restore backup)
Is there a faster way to do that? Ghost or something like that?
thanks,
JH
jeroenhermans Thu, 10/04/2007 - 00:18
You can indeed create a ghost image of the complete disk (not partition), then replace the disks with bigger models, create your raid1 setup and then ghost back your image.
DUring the ghost wizard you can then expand the size of your partitions to the capacity of the new disks.
Rgds,
Jeroen
j.huizinga Fri, 10/12/2007 - 01:58
Hallo Jeroen,
I shall give it a try (in the lab first)
thanks,
Jan
