ATA not registering, new install
Oct 4th, 2007
Hi, I have configured the ATA just like a new phone and when I connect it nothing happens. seems like its not getting anything from the tftp? red lights blinking? Is there another step that Im missing that must be configured? Pls advise, any suggestions pls. ccm 4.2.3 es44.
thanks in advance
z.zdravkov Thu, 10/04/2007 - 00:25
You may have problem with the ATA firmware. I have touched this also. Manuali upgrade it with newer firmware.
Other reason can be the Voice Vlan.
nomiel Fri, 10/05/2007 - 05:18
1. Firmware in ATA is SCCP? It can be H323, so you must to upgrade firmware to SCCP.
2. I saw some problems with registering of ATAs and there was a solution: login to web-interface of ATA and in SCCP configuration in SID0 and SID1 write "." (without quotes)
z.zdravkov Mon, 10/08/2007 - 02:24
The protocols that you can use depends on yours call agent. If you have CallManager it is better to use SCCP. You can find packet containing all the information to upgrade cisco ATA. Filename is something like There is detailed instruction in the archive how to upgrade (sata186us.txt).
