ASA 5520 Transparent Firewall Failover config
Oct 4th, 2007
Hello Pros,
Could any one give the config scripts for the ASA 5500 pair failover configuration in transparent mode.
I configured it as transparent but the failover task is left to do.
Please give the cmds for the failover for the transparent mode not for routed mode.
Thnaks
swami
Overall Rating: 5 (3 ratings)
ajagadee Thu, 10/04/2007 - 05:10
  • Cisco Employee,
-- Primary unit --
pixfirewall(config)# sh runn
: Saved
PIX Version 7.0(1)
firewall transparent
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
description LAN/STATE Failover Interface
enable password xxx
passwd xxx
hostname pixfirewall
boot system flash:/image.bin
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
ip address 172.23.58.52 255.255.255.224 standby 172.23.58.53
failover
failover lan unit primary
failover lan interface flink Ethernet2
failover lan enable
failover link flink Ethernet2
failover interface ip flink 10.0.4.1 255.255.255.0 standby 10.0.4.11
monitor-interface outside
monitor-interface inside
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
telnet timeout 5
ssh timeout 5
console timeout 0
policy-map global_policy
service-policy global_policy global
Cryptochecksum:xxx
: end
: Saved
PIX Version 7.0(1)
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
enable password xxx
passwd xxx
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
failover
failover lan enable
arp timeout 14400
telnet timeout 5
ssh timeout 5
console timeout 0
Cryptochecksum:xxx
: end
Failover Configuration URL:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/failover.html
I hope it helps.
Arul
** Please rate all helpful posts **
