How to configure VPN L2L on ASA 5505
Oct 4th, 2007
Dear All,
I would like to ask about ASA 5505.So,i want to configure VPN L2L on ASA 5505 but i don't how to configure it?i met the problem: it has Vlan1 on interface. by the way on ASA 5510 i can config it because it don't has interface Vlan1.
Could you let me know how can i solve this problem?
best Regards,
David
JORGE RODRIGUEZ Sun, 10/07/2007 - 18:12
  • Green, 3000 points or more
David, since you are not giving to much info other than one fw has vlan1 and other doesn't is hard to help. Basically what you are looking for is how to implement L2L vpn between two sites, one side being ASA5505 and other ASA5510. Here is a link with config examples between two firewalls, this applies for ASA as well.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008055bd85.shtml
Jorge
