ACS log ?????
Oct 4th, 2007
i am install ACS 2.3 in sun solaries 8.0
every device authentication authorization and accounting from ACS.
now my concern is where stored log of acccounting and it is deleted automatic after a mergin day or need manully deleted ?
i get like this The csdblog_yy−mm−dd file is created the first time DBServer starts up and is then
re−generated every 24 hours (approximate time).
thanks
Biplob
Collin Clark Fri, 10/05/2007 - 08:08
I run ACS in Windows and I have to manually move/delete the logs. I assume that the Unix version you must do the same.
