3745 and 2MFT-E1 (URGENT)
Oct 4th, 2007
Hallo!
I have 3745 router with Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(15)T1. Recently i have installed NM-HDV and 2MFT-E1 card on it. All LED indicators on NM-HDV are green, all LED indicators on 2MFT-E1 turned off.
Here is sh diag output:
Slot 2:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 0.0 Board revision UNKNOWN
Serial number 0 Part number 00-0000-00
Version Identifier FRU Part Number
Test history 0x0 RMA number 00-00-00
EEPROM format version 0
EEPROM contents (hex):
0x00: 00 CC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x30: 00 00 00 00 00 00 00 00 00 00 00 00
WIC Slot 0:
E1 (2 Port) Multi-Flex Trunk WAN Daughter Card
WIC module not supported/disabled in this slot
Unknown EEPROM ver 255
EEPROM format version 255
0x20: FF 23 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HDV firmware: Compiled Fri 19-Nov-04 14:23 by michen
HDV memory size 524280 heap free 193977
When i telnet 3745 i can not use command "controller E1" to enable and configure 2MFT-E1 card. It seems to me that i have problems with IOS feature set. Could you advice me whic IOS feature set i have to use? My requirements are: possibility to connect to telephone station (using 2MFT-E1 card), use T.37 store-and-forward fax technology, use Dynamic Multipoint VPN (DMVPN phase 1), use SSL VPN (web VPN).
If it is not possible to find IOS feature set which meets all my requriments simultaneously, then could you advice me exact IOS ver, which i can install on 2620 router, only to work with telephone station and T.37 store-and-forward fax with 2MFT-E1. On 2620 i have 64/8 memory (but can upgrade it soon).
Thnx in advance and sorry if i have made some mistakes - i'm new to telephony, faxes and so on 8)
Paolo Bevilacqua Thu, 10/04/2007 - 02:59
  • Hall of Fame,
    Founding Member
Hi, it's not a matter of IOS, what you shave "shold" work on the 3745 but the VWIC doesn't get recognized. Can you try placing it ina WIC slot and see if gets recognized? You still would not be able to use it because you have no AIM-VOICE in the router.
However, if the VWIC doesn't get recognized, you should have it replaced by cisco or where you bought it.
The 2620 not being an XM may offer only limited support for older IOS with the E1 card.
