Remote desktop through ethernet0/1
Oct 4th, 2007
Good day, I would apreciate it if somebody would like to help me set up our new router. The ISP is not very helpful. I got it connected to the net with some functionalty but I can not send mail througt the router it sais something like Relay not permited from your location. And i cant seem to get remote desktop working through the Ethernet 0/1 port. I will attach a network diagram with basic information. It any one needs more info I will suply it. PLZ Help.
nikolay-shopik Thu, 10/04/2007 - 07:06
attach your sh run output. If you can't connect with remote desktop outside probably you haven't configured port mapping correctly.
nikolay-shopik Fri, 10/05/2007 - 00:55
check you access-list 1 it's incorrect in this part
access-list 1 permit 0.0.0.1 196.25.155.158
make sure access list allow access host from FastEthernet0/1 network translated because this interface is ip nat inside.
